MTX 2300x 2 12" Kicker CVR 4ohm subs...
What is the best wiring option for this setup?? I have it setup on 1 ohm right now but it cuts off and gets very hot. Anybody have the wattage for the amp at different ohms??
RMS Power measured at 12.5 Volts DC:
150 Watts x 2 into a 4 Ohm load with less than 0.05% THD+N
300 Watts x 2 into a 2 Ohm load with less than 0.1% THD+N
600 Watts bridged into a 4 Ohm load with less than 0.1% THD+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
200 Watts x 2 into a 4 Ohm load
375 Watts x 2 into a 2 Ohm load
750 Watts bridged into a 4 Ohm load
Signal to Noise Ratio:
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thanks for the quick reply! Right now i have the speakers wired parallel. So what i need to do to get the 4 ohm load is run the positive from sub 1 to the amp, run the negative to the positive of sub 2, and the negative of sub 2 to the amp. correct??
i had one of those black mtx2300x's, it ran @ 4 ohm and did 900+watts @ 4. I blew it up and sent it in for mtx to repair and they sent it back with a birthsheet that astonished me... one of my favorite amps ever... but def def def not 1 ohm stable //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
anderlin21
anderlin21
Columbus
anderlin21
