MTX 1501D question
there was a thread not too long ago that explained in detail how to mod the 1501d. sounded real easy, i think i'll try it on mine. best thing is i bought my 1501d brand new for $300 no tax!
im running mine 1 ohm and it gets warm but these things take the abuse as well a memphis and orion amps when put under hard work and abuse of the daily driving. mine accually smoked a small component on the board but it still runs liek a champ..... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif im sure it will run more efficently after id o the big 3
The cool, nice guy that I am I will show the process again, I guess. You could give me a good rep or something since this is like the third or fourth time I have done this. But here we go.
Take the cover plate off the amp. Over on the side of the amp is a little push button (circuitry protection button) press the button to where it is UN- depressed. It is out NOT in. Look down towards the bottom of the board about in the middle and look for the Q 240 resistor. MAKE SURE it's the Q 240 resistor. Get you a soildering gun and heat it up just enough to loosen up the Q 240 resistor. I used a pair of tweezers and pulled the resistor out very carefully. Then Wha-La you are now 1 ohm and will roughly crank out 1800w rms at 14.4v.//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif Place the cover back on and it is time to wake up your neigborhood. Good luck with it
Rock On. Later......
BoomCrew
BoomCrew
Q~town, MI
SuperTrooper
