bamaboy
War Eagle!!!
using gain tutorial just to see how loud it was if i did it that way, i was highly dissapointed
using 2500rms for a dual .7 in parallel, which is 1.4 , is 59v i set it at 20/35 volume on a 45hz sine
now on 17/35 it does nothing near what it should, i turned it up a little bit, but its still not loud
since i never listen to test tones could i set it higher or set it with music? because if i set it to 59v, its just a waste of money, i could go to bestbuy and get stuff that would be louder
running at 1.4 ohms what would be the highest voltage to set at at 45hz? box is 7 cu ft so take that into effect, on my XXX i dont remember what it was set at but it was a more than the tutorial stated
this is daily only no test tones at all
