msn WTF
You're msn went through a cache dump malfunction. Basically, the code located in the cache dump that allows you to sign on and off has exceeded its capacity and didnt dump correctly. Its usually caused by changing status' from one to another frequently or signing in and out all the time.
The newer versions have a "cleaner" for lack of a better term that actually cleans the cache out every 5 minutes so that if the cache dump was to malfunction again the cleaner would take care of it so that you may go about your messaging.
hope this helps
You're msn went through a cache dump malfunction. Basically, the code located in the cache dump that allows you to sign on and off has exceeded its capacity and didnt dump correctly. Its usually caused by changing status' from one to another frequently or signing in and out all the time.The newer versions have a "cleaner" for lack of a better term that actually cleans the cache out every 5 minutes so that if the cache dump was to malfunction again the cleaner would take care of it so that you may go about your messaging.
hope this helps
woudlnt this be exclusive to my computer then? i had someone i know and trust try to sign onto my name from another computer and the same thing happened. is there somethin i can do to make this pos sign on???
regal8r
I <3 my CRX
regal8r
Lincoln, NE
regal8r
