motor noise in door speakers and tweets HELP?
I used to have the same problem when I first started installing my own stuff.
Since I was new I didnt feel I needed to use upgraded wiring and didnt know where to ground wires.
Make sure your grounds are secure and to a substantial bolt connected to metal that is in part connected to the frame of your car and that there isnt any paint between the connection of that wire and the area its fastened to.
Give that a shot. Worked for me if you are running the speakers off an amp connected to RCA's on your Deck. Consider upgrading the RCA's to a better cable such as Monster which also have grounding leads coming off of them and that will help as well.
GL and hope it helps.
gtownwhtboy
gtownwhtboy
dallas,tx
revrider1
