mosfet transistors for kicker kx1200.1
  • 5
IRF = International Rectifier. You can get crossover componants equal to them if you look hard enough.... just look up the original part specs and see how close to tolerance you find.
713
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
myjaja
SPLBassJunkie
    May 21, 2024
    May 20, 2024
