this is basically 2 amps in one chassis...its meant to run in 4ohms only ..no bridging no low load..just 4ohm...
I have used it a week....cranked it up and the amp stays cold...works great...
reason I am selling? cause my system might be a 2ohm load and I am not breaking this amp by running it incorectly...
Zed audio tested one at 386 x 2
beautiful beast of an amp $175 shipped
specs
Output power at 13.8V:
2 x 370W @ 4 ohms (0.004%)
S/N Ratio: 105dB
Crosstalk: 75dB
Damping Factor: >200 (60Hz)
Max. Current Consumption: 100A
Fuse: 4 x 20A
Dimensions: 18.8" x 11.85" x 2.05" (47.8cm x 30.1cm x 5.2cm)
pics of internal
http://ampguts.realmofexcursion.com/Eclipse_34230/
specs
S/N Ratio: 105dB
Crosstalk: 75dB
Fuse: 4 x 20A
pics of internal
