Mono amp with outputs for 2 subs
CHUMCHAL72
So I have a mono amp and it has 2 sub outputs and I want to wire it to 2 subs
So my question is to just use one output and wire it at 2 ohms
Or can I use each output to each to each sub and if I can how would I do that and would it be enough power to each sub
Here's the specs of the amp/subs
The amp is a monoblock class D
4 ohms: 450w x 1ch
2 ohms: *900w x 1ch
1 ohms: 1200w x 1ch
10" SVC 4 ohm
Peak: 600w
RMS: 300w
So I have a mono amp and it has 2 sub outputs and I want to wire it to 2 subs So my question is to just use one output and wire it at 2 ohms
4 ohms: 450w x 1ch
2 ohms: *900w x 1ch
1 ohms: 1200w x 1ch
10" SVC 4 ohm
Peak: 600w
RMS: 300w
I had the same question last week. I was told it is for ease of wiring. Both negatives are connected to the same contacts in side as well as the positives. You can wire to either pole and be ok.
4 ohms: 450w x 1ch
2 ohms: *900w x 1ch
1 ohms: 1200w x 1ch
10" SVC 4 ohm
Peak: 600w
RMS: 300w
The 2 outputs on a Monoblock are for ease of installation for wiring multiple subs. With two 4ohm SVC subs, you can do either....wire them internally in the box and run one wire, or run both subs to the amp and use both outputs....the power output will be the same either way.
Well with just using the one output the way I was told to wire I would get 450w to each sub then turn the gain down
So how would I wire with 2 outputs and how much power would I get to each sub
Then what explains 2 positive terminals and 2 nigitive terminals
Ease of installation....it is a mono signal, no matter what. Personally, I use both sets of +&- for my set up. But the power out put is just the same as if I were to run one wire from the amp and split it to the 2 subs. I just like using 2 individual runs. The amp does not put out any more power into a given impedance, if you use one set of outs or both...the power output is the same and is divided by the # of subs used, assuming they are all the same type.
Ok so how would I hook up my subs with it them
It says I can wire it in parallel and ger the right load of watts so if it's wired internally could I just hook up each sub to each terminal
+ve end goes to +ve on amp, likewise -ve.
CHUMCHAL72
CHUMCHAL72
Victoria, TX
chargdbassbuick
