Just an idea I had, I set my gains with a DMM and a test tone at 50hz to 350wrms but I know that during actually playing music it generally never reaches the levels that a test tone does.
My idea would be to have a dmm in parallel with the sub monitoring the voltage and making sure it doesn't go over the voltage I set it at when the bass hits. sqrt(350*2) = 26.45V in my case. If I do this would I be able to up the volume as long as it doesn't exceed that voltage and be safe? Obviously not maxing out the HU though as to avoid clipping. Doing this the max volume on every song will be different, but I'd say it should give me a nice amount of a bass upgrade.
With regards to bass boost, I never use it, but I was also wondering if there was any advantage to using it but making sure the voltage never exceeds rms. When I was setting my gains I noticed bass boost added a fair bit of voltage to the amp outputs, so if I turn the gain down a little bit to compensate and the bass boost up a bit, would there be any advantage to this? or would the volume be the same because the sub is still seeing the same amount of power?
Cheers.
Cheers.
