modded mtx1501d
Before I go on, was yours straight from tha factory, or modded?
before you go on, mayby you should stop and think... the protection circuit shuts the amp down if it sees below a 2ohm load, considering i said i had it @ 1ohm thats common sence there slow buddy //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
its ok, im sure the short bus had some advantages
yep ricky, but 81000d = 1501
Mine is modded to surpass tha protection, be .5 stable & hold 18v for burps (IIRC, I may be wrong), I'll get more information on this because I wasn't who modded this.
No need to be a smartass. I was asking a simple question, no reason to be a prick. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
very powerfull amps ... although i would never take it to .5 ohms... mine fried @ 1ohm after a few months of hard abuse ...
i had mine on 2 12" L7s and it made me halfway deaf
are you reffering to a reg one or a modded one that was the cause of it blowing at 1 ohm?
ive had extensive experience with 2 of these babies for a long time under several load sand conditions.
first off, the portection circuit is just for the DC input volatge so itll go up to 18v or whatever. has nothing to do with how low u can drop the ohms on them, thats straight from MTX.
secondly, .5ohm nominal (.35ohm dcr) is bad with these. itll burp, but anything more than 5 min of straight bass will heat them up hardcore. i mean realllly quick.
1ohm nominal (.7ohm dcr) will take daily up to an extent. thing is itll get pretty warm after a while, ten itll get HOT after a while....if you keep running it afterits hot and shuts off once, then youl blow it. it took about an hour and 45min of straight bass, bass test songs, heavy rap, and tones (yes tones too) at .7ohm dcr for mine to blow. even then it shut off once of twice befor ei kept pushing it till smokage...even then it took a fairly hard *** beating to get it to that point. you can do .7ohm dcr daily but after about 45min itll get pretty warm, just be aware of the temp of the amp and if its hot enough to burn the shyt outa ur skin, give it a rest
than being said, it is still a quality amp and for 200-240 it's a SOLID *** piece of equpiment for the price. anything over 250 is still reasonable, anything over 275 i wouldnt do it...i apid well over 300 for mine a few years ago and it hought they were well worth it. if you can getem for a good price do it, they'll take some abuse and burp .5ohm nominal
Bumpin97Jeep
Bumpin97Jeep
Ga
BassAddictJ
