RetroAudioinc
Custom Car Audio Decals
Ok I have a few questions. NOTE: This is going in a Chevy 2500 with a camper shell window open so all this is going in the bed and to be pointed though the window opening.
I was told today not to mix sub sizes IE 4 18's and 4 12's would be bad. Is this true?
Is it ok to mix brands but same size says I have 4 Pioneer SPL's 12's and 2 RE Audio 12's?
--- Now if the above is ok do you split them on apms Pioneer's on one and the others on another amp.
I am sure the rule is to keep all the same size is best but how or why is it bad to mix sizes, I would think the 18's would give me that super low and the 12's a little faster response or did I just answer my own question there it would sound bad?
I will be using a U.S. AMP VLX-400 Competetion Amplifier for the subs it's rated at 5000 Watts RMS and good to 1/4 OHM so I think it will be the better amp. I also have the Memphis MCD-4KW Mojo 4000 Watt Amplifier and Rockford Fosgate T40001BD so thats what I have to pick from in amps what would be best for what speakers below?
Speakers I have:
18's
4 INCRIMINATOR AUDIO DEATH PENALTY 18"s
15's
2 15" Rockford Fosgate Punch HE2
Or mixing these two together but same sizes and using 2 of the amps above.
2 PIONEER TS-W5102SPL 12's
2 PIONEER PREMIER TS-W3001D4 12's
2 RE Audio SE12D4
4 KICKER CVR12 COMP VR 12"
4 Kicker Solo-Baric L7 Series 12" 2 OHM
I do want to go to SPL comps so I am trying to find the best setup for that so any help would be super.
Thanks
Brad
Speakers I have:
18's
15's
2 RE Audio SE12D4
Thanks
Brad
