MINT Alpine 9887
Skip01
Diggy
1. Product:
Alpine 9887
2. Specs:
Alpine Electronics of America, Inc.
CEA-2006 Power Ratings
CEA-2006 Power Rating: 4 I? @14.4V Ƈ%THD+N, S/N 80dBA (ref.1W into 4 I?), 18W x 4
Max Power Output Ratings
Max Power Output: 50W x 4
FM Tuner
Tuning Range: 87.7-107.9 MHz
Mono Usable Sensitivity: 9.3dBf (0.8 A?V/75 ohms)
50dB Quieting Sensitivity: 13.5dBf (1.3 A?V/75 ohms)
Alternate Channel Selectivity: 80.0 dB
Signal-to-Noise (S/N) Ratio: 65.0 dB
Stereo Separation: 35.0 dB
Capture Ratio: 2.0 dB
AM Tuner
Tuning Range: 530-1, 710kHz
Usable Sensitivity (IEC Standard): 22.5/27.0 (A?V/dBf)
Disc Player
Frequency Response: 5-20k A?1 dB
Channel Separation (at 1kHz): 85dB (at 1kHz)
Dynamic Range (at 1kHz): 95 dB
Total Harmonic Distortion (at 1kHz): 0.008% (at 1kHz)
DAC Type: 24-Bit DAC
Wow & Flutter (%WRMS): B.M.L.
Oversampling: 8x/352.8kHz
Signal-to-Noise Ratio: 105 dB
Connection for iPodA?
MP3 Decoding: MPEG-1/2 AUDIO Layer-3
WMA Decoding: Windows Media' Audio
AAC Decoding: ACC-LC format ''/m4a'' file
Number of Channels: 2-Channel (Stereo)
Sound Tuning
Subwoofer Level Adjustment: -15dB to 0dB (1dB steps)
Bass Level Control Range: +/-14dB at 100Hz
Bass Center Frequency: 60/80/100/200Hz (Selectable)
Bass Band Width Adjustment (Q): 4 choices (1 =wide, 4 =narrow)
Treble Level Control Range: +/-14dB at 10kHz
Treble Center Frequency: 10k/12.5k/15k/17.5kHz (Selectable)
MediaXpander Modes: FM, CD, XM, MP3, (Level 1, 2, 3, Off), DVD Video (Level 1, 2, Off), DVD Music (Level 1, Off)
MediaXpander Aux Settings: MP3, Music, Movie, (Level 1, Off)
Equalizer: 5 Band Parametric (20Hz - 20KHz, 1/3 oct. Steps), 7 Band Graphic
Time Correction: Adjustable 6 Ch. Time Correction (L-F/R-F/L-R/R-R/L-SW/R-SW)
Crossover Frequency: Flat/6/12/18/24dB oct., 20-200Hz (High-Pass/Low-Pass)
IMPRINT: Automatic Acoustic Correction & Computer Interface (KTX-100EQ Required)
Remote Control
Remote Control: Included
Model Number: RUE-4202
Battery Type: AAA Batteries (2 pcs.)
Dimension (WxHxD) mm : 42mm x 121mm x 23mm
Dimension (WxHxD) in : 1-21/32'' x 4-25/32'' x 29/32''
Weight: 1.5kg (3lbs. 4oz.)
Dimensions
Din Size: 1
Chassis Size (W x H x D) mm: 178mm x 50mm x 160mm
Chassis Size (W x H x D) in: 7'' x 2'' x 6-1/4''
Nose Piece Size (W x H x D) mm: 170mm x 46mm x 24mm
Nose Piece Size (W x H x D) in: 6-3/4'' x 1-13/16'' x 15/16''
General
Power Requirement: Power Requirement: 14.4 (11-16) V.DC
Pre Output Voltage (Before Clipping): 4V
Operating Temperature (A?C/ A?F): 60 A?C (140 A?F) to -10 A?C (14 A?F)
Maximum Mounting Angle: 30A? from Horizontal
Weight: 1.6kg (3lbs 8oz)
FEATURES
Tuner
Memory Presets: Preset Stations (FM:12/AM:6)
Memory: Auto
Seek Mode: Local/DX Selection
HD RadioA?
HD RadioA?: HD Radio Ready
Connection: Alpine TUA-T500HD Required
Status Indicator: HD Radio Satus Indicator
Signal Switching: Automatic Digital/Analog
Multi-Casting: Multi-Cast HD1, HD2, HD3
BluetoothA?
Parrot Bluetooth Module Built-In: Bluetooth Ready
Hands Free Calling: Hands Free Calling
Music Streaming: Streaming Music Playback
Music Streaming Control: Streaming Music Control
Connection: Alpine KCE-300BT Required. Features may differ between phone model and service providers.
Phone Book: Phone Book Transfer
Compatibility for iPodA?/iPhoneA?: Full Speed Connection: iPhone, 4th/5th Gen. iPod Video/Photo, iPod mini and iPod nano
Connection Type: Full Speed Connection for iPodA?
Connection: Full Speed Cable (KCE-422i)
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Playlist
Percentage Search: Percentage Search
M.I.X. (Shuffle) Capability: Song, Albums, All
Connection for USB: Dedicated iPod Source
Music Control: Song Up/Down/Repeat
Information Display: Artist, Song, Album
Easy Navigating: Quick Search
Satellite Radio
SiriusXm Ready: Satellite Radio Ready
Connection: SIRIUS or XM
Satellite Provider Capability: SIRIUS or XM Adapter Required
Preset Memory: 3-Bands (6 Per Band, 18 Channels Total)
Easy Navigating : Quick Search
Music Information: Category, Artist, Song
Portable Compatibility: SIRIUSPlug N Play Devices (Adapter Required)
Disc Player
Disc Type: CD Player
Disc Playback Type: CD/CD-R/CD-RW
Music Playback: MP3/AAC/WMA Playback
Music Sensor: Scan/Repeat
Playback Control: Play/Pause/Forward/Back
Title Memory: 18 Disc Title Memory Display (Disc Only)
M.I.X. Random Play: One (Folder)/All (Random Play)/Random (CD Only)
DAC: 24-Bit DAC
Zero data Mute: 0 Bit Mute
Digital Servo: Digtal Servo
Sound Tuning
Subwoofer Level: Subwoofer Level Adjustment
Equalizer: Built-In Graphic/Parametric Equilizer
Bass Level: Bass Level Adjustment
Bass Center Frequency: Bass Center Frequency Adjustment
Bass Bandwidth Adjustment: Treble Level Adjustment
Treble Level: Treble Level Adjustment
Treble Center Frequency: Treble Center Adjustment
MediaXpander: Built-In MediaXpander
Time Correction: Built-In Time Correction
Crossover: Built-In High-Pass/Low-Pass Crossover
IMPRINT: IMPRINT Sound with MultEQ Acoustic Correction (KTX-100EQ)
CD Changer Control
M.I.X.: One/All (Shuffle)
Multi-Changer Control: Multi-Changer Control Including MP3 Changer CHA-S624, (with KCA-410C)
Music Text Information: CD:Text Scroll Display, MP3: Text Information Display (ID3 Tag)
Music Control: Play/Pause/Forward/Back
Repeat: Song/Disc
General
Power Output: 50W x 4 High Power Amplifier
Display: 2 Line Biolite Display
Control Type: Rotary Encoder Knob
Illumination Buttons: Blue
PreOut: 3 PreOut (4V PreOut)
Steering Wheel Remote Control: Steering Wheel Control Ready
Clock: Built-In Clock
DIN Trim Plate: Detachable Trim Plate
Detachable Face Plate: Detachable Face Plate
Dimmer: Dimmer Input
Power Antenna Lead: Power Antenna Output
Remote Turn-On: Amplifier Remote Turn-On Output
Audio Interrupt: Audio Interrupt Input
CD Changer: CD Changer Control
Face Color: Gunmetal Black
BluetoothA?: Bluetooth Ready
DAC: 24-Bit DAC
Auxiliary Input: Versatile-Link Ready
Bass & Treble: Bass & Treble Controls
Fader & Balance: Fader & Balance Controls
Mute: Built-in Audio Mute
Remote Control: Remote Control Included
3. Description/Condition:
Hella mint....no scratches anywhere...all buttons look like theyve never been touched.
Comes with a Scosche Ipod cable hook up
Original Remote
Original Packing
4. Price: :
$235 shipped
NO TRADES
5. Pictures:
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
** DO NOT DELETE ANYTHING BELOW THIS LINE OR THREAD WILL BE DELETED **
This message is automatically inserted in all classified threads.
Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment:
1) Telephone number. Call the number back at a unspecified time and make sure that it is the person's correct phone number.
2) Name and address including postal code
3) Valid e-mail address. Send an e-mail requesting a response to information about the deal being made.
DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
If transaction was completed on CACO, please use iTrader to record feedback.
Potential buyers/seller should check iTrader feedback also before continuing transaction.
Skip01
Diggy
Skip01
Marrero,LA
rumblefish
vegang
vegang
