Millertime1028's 20K summer build
More Pics to Come! and good guess P3bump
Thanks for the comments guys! Should have them hooked within a few days, letting them soften up a a little and then the testing shall commence! Will be doing a direct comparising against the last (4) different models/brands of subs that I have used and tested in the same box, on the same power.
you selling the xl's
Going to hold on to them for alittle while.
Those subs would be great with my 2 4500s //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Don't make me call you up and work out a deal lol....
Some more pics before they go into the box..These are utilizing the new cones and surrounds.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif ... Pretty sure the amp is called an AQ 20k. I have clamped this with results upwards of 14k. Take into consideration the amp is running in 16.5v setup at .5 ohms. Also, this amp does well above 8k. Many clamp tests have been done on this which yeilded well above 10k with high imp rise and low input voltage. Will be doing some tests with a CS k12 soon so we shall see how the two amplifiers compare.
So dynamic power means something now? I didnt look into the build enough to see you were running at 16.5v and .5 but it still should be called a 14k build :p
Millertime1028
Millertime1028
Long Island, New York
The_Grimy_One
