what are the specs of both? thanx, peaceMemphis MOJO's and Earthquake D3's for sale all 4 are used
the D3's are modded
the MOJO's are stock
500 for the D3's plus shipping
600 shipped for the MOJO's
email me for more info and pics
mojowhat are the specs of both? thanx, peace
NG
will u take like 425 for the amp?mojo2400 at 2 ohms
more like 2700 rms at 2 ohms
can be burped at 1 ohm with no problems
D3
modded to burp at .25
1 ohm stable daily
tested to make 5k peak at .7 with 13.3 volts
look up!!!Memphis MOJO's and Earthquake D3's for sale all 4 are used
the D3's are modded
ok u didnt answer my question....and what amount of amperage do these pulllook up!!!
these are way below cost!! these are thousand dolar amps here!! can't go that low
I beleive I did when I said I can't go that low!!! prices are listed in the original postok u didnt answer my question....and what amount of amperage do these pull
what about @ .25ohms and .7ohms?I beleive I did when I said I can't go that low!!! prices are listed in the original post
150 amps peak daily
ey man if its 300amps that works for me..what does the amp fo @ 4ohms?and its 4kw @ 1ohm correct?in a all out spl setup, the D3 will pull 300 amps of current MAX
never tested at .25 even tho they are capable, we only had dual .7's in our van!! 250 amps at full tilt at .7 for spl, around 180 or so for daily
for daily, the lowest I would go is 1 ohm for daily, .7 should be okay too after imp raise. Just make sure to keep the voltage up no matter what.
