Memphis Mojo 4KW, Audiopipe AP30001D
ldyzlvudis06
turbo'd 3800
IL
I have
(1) Memphis Mojo 4KW
(1) Audiopipe AP30001D
The Memphis 4KW has a few scratches and missing the endcaps but that doesn't affect its powerful performance. specs are below
Continuous power output at 14.4 volts:
-4 ohm 1000wrms x 1 @ .5% thd
-2 ohm 2000wrms x 1 @ .75% thd
-1 ohm 4000wrms x 1 @ 1% thd
Signal to noise ration: 95db
variable low pass: 50hz-250hz 18db/oct.
variable highpass subsonic: 20hz-50hz 18db/oct.
damping factor >50
Protection circuitry against overload, short circuit, thermal, and reverse polarity.
Bridgable at 2 ohms for 8000rms.
Dimensions: 31.49" x7.6" x 2.4"
-Audiopipe AP30001D
This amp comes with bass knob, owners manual original box it was purchased in July of 2010 and always ran at 2ohms specs are below
Power Amplifier: 3000 Watts
• Channel: 1 Channel Class D
• Frequency Response: 8Hz - 18KHz
• Signals to Noise Ratio: 70db
• Bass Boost: 30-80Hz
• Input Sensitivity: 0.2-5V
• Subsonic Filter: 5-50Hz
• Low Pass Filter: 40-180Hz
• Output Power (RMS):
1 Channel @ 2Ω - 3000W
2 Channel @ 1Ω - 1500W
• Dimension: 710x176x55mm
Memphis 4KW I'm looking to get $600 shipped OBO
Audiopipe AP30001D $250 shipped or trade for D2 12" sub can also add cash
ldyzlvudis06
turbo'd 3800
ldyzlvudis06
IL
iLockdown
