Sold Memphis M-Class 16-MCD1000 Amplifier amp 1100 WATTS 1 Ohm stable
gsxromer8642
Here is a Memphis 16-MCD1000 mono D class amp. This thing is a beast, it can push any sub hard. Below are the details. I bought it with the intention of using it but i have changed my setup and can no longer use this one so here is you chance at a great amp! there are a few scratches here and there but not bad and I lost one of the screws on the amp but i put in a small bolt that does just fine. will add pictures with username but if you check my other adds i took the pictures on the same counter. I know i'm new to this site but i'm on dsmtrader.com under the same username and on ebay (fresh2death42748) I'm asking 260$ shipped. Thank you
Class D Monoblock Subwoofer Amplifier
Compact Aluminum Chassis with Custon Black Pearl Finish
RCA Outputs: 1 Pair
Gold Plated RCA Connectors
Full MOSFET Design
Built-In Fully Variable Low Pass Filter: 50 - 250 Hz
18dB Per Octave Crossover Slope
Built In Fully Variable Sub-Sonic Filter: 20 - 50 Hz
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
Optional Wired Remote Gain Control
RMS Power Ratings:
300 watts x 1 chan. @ 4 ohms
600 watts x 1 chan. @ 2 ohms
1100 watts x 1 chan. @ 1 ohm
Adjustable Input Sensitivity: 200mV - 4V
Dimensions: 15.75" L x 7.6" W x 2.4"
Amplifer Class - D
Number of Channels - 1 - Mono
RMS Power (4 ohms) - 300 watts x 1 channel
RMS Power (2 ohms) - 600 watts x 1 channel
RMS Power (1 ohm) - 1100 watts x 1 channel
Bridged RMS Power - N/A
Total RMS Power Output - 1100 watts
Peak Power Output - N/A
Minimum Impedance Unbridged - 1 ohm
Minimum Impedance Bridged - N/A
TDH at Rated RMS Power - .75%
Speaker Level Inputs - No
Preamp Outputs - 1 pair
Build-in Crossover - Low-Pass/High Pass
Low-Pass crossover frequency - 50-250 Hz
Subsonic Filter - 20-50 Hz
Signal-to-Noise Ration - 95 dB
Bass/Gain Remote - Optional
Fuse Rating - 40a x 2
gsxromer8642
gsxromer8642
Tucson az
jwillis4
