Memphis Big Belle went to protect, nothing is burnt?
alex5857
So my big 5 channel belle went into protect, and everything turned off, all my speakers including my sub, i opened it up and all the fuses are good, and there is nothing burnt inside.
I noticed when it was still plugged in that it would make my car idle rough, so im guessing it was pulling alot of amps. also one of my speakers was making a high pitched sound every couple seconds, and it was also on the amp (the sound)
if you have a multimeter set it to ohms. check to see if you reqad anything near 0 ohms between the legs of the outs inside the amp.
Black probe on leg 1 of the out red probe on middle leg
then black probe on middle leg and red probe on leg 3 of the outputs Do you reading anything near 0 ohms check all outputs post your results
alex5857
alex5857
California
mike49504
