//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifLOW VOLTAGE LIKE WHAT 10VOLT 9VOLTS 8VOLTS. I HAVE A 120AMP ALT STOCK AND NSB125 UP FRONT AND TWO NSB90S IN THE BACK WILL I BE SAFE IF I RUN THE MEMEPHIS 4KW.
40.1 see test specs for 15v
stock alt is probably gonna fry or the amp is gonna poof on a 120 amp alt - these amps can pull several hundred amps constant.
