Got a Memphis 16-MCD4KW and 16-MCA2004 for sale. I would like to sell them together but if I get a buyer for both I can split.
Memphis 16-MCD4KW pics and stats:
4000W RMS, Class D Monoblock MOJO Series Amplifier
Price $650 shipped
This amplifier has a beauty that runs much deeper than its customer black pearl finish. Its super efficient microprocessor-controlled power supplies produce amazing bass on less electrical current than most ordinary amps and generate less heat. Most monoblock amplifiers are not bridgeable, but with a special Memphis device, you can bridge together two of these amplifiers to double your power. This amp runs a true 4000 watts of clean power at your disposal.
* MOJO Series Monoblock Class D 4000W Max Amplifer
* RMS Power Rating:
o 4 ohms: 1000 watts x 1 chan.
o 2 ohms: 2000 watts x 1 chan.
o 1 ohm: 4000 watts x 1 chan.
* Max power output: 4000 watts x 1 chan.
* Total Harmonic Distortion:
o 4 ohms: 0.5%
o 2 ohms: 0.75%
o 1 ohm: 1.0%
* MOSFET power supply
* Remote bass level input (remote level control sold separately)
* Power, protection and blown fuse LED indicators
* Custom black pearl finish
* Signal To Noise Ratio: 95 dB
* Input Sensitivity: 250mV - 9V
* Input Impedance: 22Kohm
* Damping Factor: >50
* Output Impedance: 1-4Ohm
* Includes 0 gauge fuse holder with two 250 amp ANL fuses
* Low heat generation
* Gold-plated RCA inputs
* Buffered RCA low level output (loop through)
* Variable low-pass filter (50-250 Hz, 18 dB/octave)
* Variable high pass subsonic filter (20-50 18dB/octave)
* CEA-2006 compliant amplifier
* Dimensions: 31-1/2"L x 7-5/8"W x 2-1/2"H
* 0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Memphis 16-MCA2004 pics and stats:
300W RMS, 4-Channel MClass Series Amplifier
Price $150
# 4-Channel MClass Series Amplifier
# Compact Aluminum Chassis with Custon Black Pearl Finish
# Gold Plated RCA Connectors
# RCA Outputs: 1 Pair
# Full MOSFET Design
# Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
# 4-Way Protection Circuitry
# Platinum Finish Wire Connections
# Accepts 4 Gauge Power and Ground Wire
# Optional Wired Remote Gain Control
# RMS Power Ratings:
* 50 watts x 4 chan. @ 4 ohms
* 75 watts x 4 chan. @ 2 ohms
* 150 watts x 2 chan. @ 4 ohms bridged
# Adjustable Input Sensitivity: 250mV - 5V
# Dimensions: 14.1875" L x 7.6" W x 2.4" H
Combo Price $750 shipped.
Would trade for a IA 40.1 or Sundown 3500D.
Price $650 shipped
* RMS Power Rating:
o 4 ohms: 0.5%
o 2 ohms: 0.75%
o 1 ohm: 1.0%
Price $150
