This is a Memphis 16-ST1000D amplifier. Originally listed for $650.
Will sell for $200.00+shipping
The 16-ST1000D is a single-channel, class D subwoofer amp featuring line-level outputs, an 18 dB-per-octave lowpass crossover that's continuously variable from 250 Hz to 50 Hz, and a defeatable subsonic filter that's continuously variable from 20 Hz to 50 Hz. Power ratings for this amp are listed as 300 watts into 4 ohms, 600 watts into 2 ohms, and 1100 watts into 1 Ohm.
This is a used amp. It was hooked up to 4 JL Audio 10W3 subwoofers and rocked!!! It was used about 15-20 times since I had an on/off switch installed in my Jeep. Memphis is known for it's power so if you want an awesome amp at a great price then this is the amp for you!!
Some additonal information is below:
All measurements @ 14 volts unless otherwise specified:
Frequency Response (4 Ohm IHF Load 80 Hz Ref. Crossover @ highest setting): +0 dB, -.9 dB (Crossover -3 dB @ 249 Hz)
L/R channel error max deviation 20 Hz to 20 kHz: N/A
Signal-to-Noise Ratio (Below Rated Output, "A" weighted): -79 dB
Distortion at Rated Output @ 60 Hz: .4% @ 300 watts into 4 Ohms; .5% @ 500 watts into 2 Ohms; 1.1% @ 1100 watts into 1 ohm
Output Power (Resistive) (2 ohms @ 60 Hz to 1% THD+N): 791 watts @ 14 volts; 643 watts @ 12.8 volts; 231 watts @ 10.5 volts; 425 watts @ ***
Output Power (Resistive) (1 ohm @ 60 Hz to 1% THD+N): 997 watts @ 14 volts; 886 watts @ 12.8 volts; 246 watts @ 10.5 volts; 688 watts @ ***
Output Power (Reactive) (2 ohm IHF Load @ 60 Hz to 1% THD+N): 846 watts
Crosstalk @rated output, 20 Hz to 20 kHz: N/A
Damping Factor @ 100 Hz: 25
Voltage for Rated Output: 182 mV to 4.5 volts
Idle Current Draw: 1.7 amps
Current Draw @ 1/3 Maximum Power: 33.2 amps @ 332 watts
Efficiency @ 1/3 Maximum Power: 71%
Power-Up Noise: 51.3 dB SPL
Power Down Noise: 51.1 dB SPL
*** Output Power @ onset of clipping.
