Sold Memphis 16-MCA300 2 channel Class AB Full Range Amplifier!
Shinju
I was saving this in hopes of trying to find a MCA1000 or MCA1500 for another build but could not find one at a price point I was willing to pay.
Amplifier works perfect looks brand new, Only flaw is the 2 tabs that hold the power/speaker side topcap on are gone. The Topcap still stay's in place but will not lock down, A small cosmetic flaw doesnt affect the amplifiers working performace.
The Amplifier has never been breached still has the warranty sticker intact on the bottom plate.
Asking 200.00 shipped No trades please.
Specs:
12v ratings from what I can find.
•Full MOSFET Design
•Built-In Fully Variable High/Low Pass Crossovers
•Use Selectable 12dB or 18dB Per Octave Crossover Slope
•RCA Bypass Output
•Platinum Finish Wire Connections
•Accepts 4 Gauge Power and Ground Wire
•2-Channel MClass Series Amplifier
•Compact Aluminum Chassis with Custon Black Pearl Finish
•Gold Plated RCA Connectors
•RCA Outputs: 1 Pair
•Full MOSFET Design
•Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
•4-Way Protection Circuitry
•Optional Wired Remote Gain Control
•Adjustable Input Sensitivity: 250mV - 5V
•Dimensions: 18.09" L x 7.6" W x 2.4" H
•Number of Channels 2
•RMS Power (4 ohms) 150 watts x 2 chan.
•RMS Power (2 ohms) 240 watts x 2 chan.
•RMS Power (1 ohm) Not Stable
•Bridged RMS Power 480 watts x 1 chan.•Peak Power Output 960 watts approx.
•Min. Impedance Bridged 4 ohms
•THD @ Rated RMS Power 0.03%
•Amp Preamp Outputs Yes - 1 Pair
•Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz)
•Signal-to-Noise Ratio 88 dB
•Fan Cooled No
•Fuse Rating 25A x 2
Shinju
Shinju
Seattle
Shinju
