Memphis 16-MC5.1400 - a pop, and then no sub output
sdbarker
WA
The other day, at low volume (seriously!) I got a pop from my 16-MC5.1400 through my sub channel, and then no more sub output. I've verified that the subs are functional by way of hooking them up to one of the 4-channel outputs, and verified that the sub-output is dead by hooking my 3-way speakers to the sub output and getting no output. Is there a fuse somewhere that I can't find that I could replace? I'm *really* hoping that this amp isn't dead!
Thanks for your help!
No fuse on that amp, if you got a pop through the subs it sounds like the sub channel went south on you. You could try switching rca's to the sub channel but unless you did something to damage an rca wire it sounds like the sub channel went out
****, that's what I was afraid of. For now, I've got my front stage running off of deck power, my rear stage is running from the amp's front stage, and my subs are running from the amp's rear stage.
Time to find a suitable replacement.
sdbarker
sdbarker
WA
sdbarker
