Melting 8ga Power Wire
Shit, I have a 00 monte ss,, before i did the big three. I couldnt pull more then 1000 watts with a 4 awg power wire, Let alone you are using a 8 awg wire.. pics?
When I first got my Rockford T10001bd I had 2, 2 foot long runs of 8g from the distro block to the amp until my 1/0 came in from Knukoncepts. By the time it got here the red shielding was black //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif But like they said be careful cranking the gains like that or you will burn up more than power wire. With 5v preouts I set the gain on my T1k to 1050 watts with a DMM. Gain was only 1/4 of the way up.
my first fuse/fuseholder 4 ga melted. the one right off the batt.
i dont know hwo it happened. but when i went to change my blwon fuse, it was liek that.
blew the fuse by shorting the circuit. left a ground wire open =x
When I had my Kicker kx1200.1, and my 2 15" L7's, I had no problems at all with the 8gauge. I was running at 1ohm, at that amp was birthsheeted at 1420w. For some reason this Kenwood is less efficient I guess...
I can get pics later today if you'd like. I think I may have thrown the wire away, but I still have the fuse holder i think.
Ok, I was just reading the gain setting tutorial... 42.7v is what i need. When I get my new 4ga and fuse holder I'll set it to that.
As for the test tones, I already have 0db tones from 15hz to 1khz. As a matter of fact, I melted all my shit on a 0db 35hz tone... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D
Then you really were drawing 900w through the wire. Awesome.
I melted an 8 ga wire and fuse holder in my 4runner with a 4 ch Infinity amp a few years back. It was hilarious. For a few days, I couldn't understand why my amp wasn't working. I went to check my oil and finally noticed it //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif I run 4 ga now.
DeboDaddy
DeboDaddy
St.Louis
LBC99
