mekp (epoxy hardener) = HIGH EXPLOSIVE!!
Insomniac119
i can't sleep
MEKP, methel ether ketone peroxide, is a high explosive. Don't worry, the stuff you buy for use as a hardener will not blow you up. You'll have to synthesize your own mekp if you want it to, but the kind you can buy is still explosive.
Here is a vid of nitromethane (fuel used in really fas cars) sensitized with epoxy hardener: http://ww1.webtop100.net/~62552/xmovies.webtop100.net/banners/plx.mpg
I just though it's be a cool peice of trivial information.
I dont get it, first you say its explosive, then you say the stuff you buy isnt, but then you say it IS again, wtf mate?
the kind that is sold with epoxy based products is not highly combustible like the kind one can synthesize.
not hard to understand really. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Well, epoxy hardener alone will not detonate. But apparently it can be used to sensitize other explosives, I just found this out today and thought I'd share it with you all.
Insomniac119
i can't sleep
Insomniac119
Wichita, KS
Alpineinstaller
