Measure current directly?
Either. I guess I'm thinking like some kind of inline tester that will measure amps.
Umm... yes... it's called an ammeter (that's the correct spelling, not AMPmeter).
I have one that'll measure up to 60 amps. It goes in series with the alternator wire. Anything higher than that and you'll need to build it yourself from a shunt and a millivolt meter.
Current Shunts can be had from Simpson Electric:
http://www.simpsonelectric.com/accind.htm
If you had a shunt that was rated 100 mv at 100 amps, then each millivolt (.001v) would be an amp. Measure the voltage with your DMM on the lowest scale.
Nightskye
Nightskye
East Bumfvck
maylar
