me and jackhammer
nope never seen it. I would love to know the technology making the circuitry so much more efficient than most other amplifiers.
do you know anythings about electronic circuits ?
do you know anythings about class-d power amplifiers ?
do you know anythings about ultra class-d power amplifiers ?
finally...do you know anythings about class-j power amplifiers ?//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
this amp...working on class-j...on this class...amplifiers have higher efficiency of other class....with good sound guality(s.q).
actually this amp...have fantastic design...i talking about smps(do you know that ?//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif)...& i talking about out put amplifier circuit...
pdx series of alpine...have 90% of efficiency but this amp...have 95% of efficiency...
we tested them...(with volt & ampere meter on terminlas of power & terminlas of out put speaker)..with nearly power out to max rms power (nearly 900-1000w)...after 15-30 min...this amp was very very low temperature...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
PH10000W/D1
Number of channels: 1/Mono
Class: "D"
Max Power Output: 5000 Watts / Linked = 10000 Watts
Damping Factor: >800
Cross Over Slopes: 24dB/OCT
THD: >0.016
SNR: 104dB
Speaker Connections: 8-Gauge
Power/Ground Connections: 0-Gauge
Input Types: Low Level RCA Inputs
Dimensions (HxWxD): 2.375" x 10.125" x 16.5"
MSRP: $1,498.00
You sir are retarded. that is the specs from Earthquake
hmmm lets see here a 5000w peak, so roughly 2500wrms. Also the class"J" is the dumbest thing i haver heard in literally years. If you would like please call 510-732-1000 and they will laugh in your face. It is posted all over there site it is a D class amp.
PH10000W/D1 Number of channels: 1/Mono
Class: "D"
THD: >0.016
SNR: 104dB
MSRP: $1,498.00
yeah.. so
shut the fuck up retard.
BTW let me remind you again, I had a sponsored car by them and ran there amps for years, and also went through countless amounts. Believe what you will in fairy land but in real life you would get more power out of spending 350-400 on a nice Orion 2500d
Your english is very good, considering you are from Los Angeles. Kudos to you.
Do the chickens have large talons?
who is this designer 2002 punk anyways, kid is a new member with no knowledge of CA appearantly and starts out by calling out 80 and myself on our knowledge then he goes on to argue about "j class" ph10,000s lol
WTF is J-class, or what does he claim it to be?(summary)
He speaks arabic as I saw him recently posting to the OP, im guessing its just the OP on another name, someone should check IPs cause im to lazy or im guessing its one of his friends.
BTW here is a bench test of the PH20,000 from ROE amp guts.
(this is just 2 PH10,000 boards together)
Output Power at 16V:
2 x 1496W @ 4 ohms
2 x 2292W @ 2 ohms
That is at 16Vs I would hate to see what it would put out at 12.8 on a 10,000
amir_clk500
amir_clk500
dubai
60ndown
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
