MDF plywood?
jcuts7171
im getting ready to build my box and i got the all the supplies and the mdf plywood, its marked 4x8 x3/4'' thick...but i had measured it when i got home and it measures 5/8'' thick....is that 1/8" gonna make a difference...i see that you need to use 3/4"....what to do?..............thanks
it may be 3/4" MDF...
all wood loses size when it's fabricated
for instance 2 x 4's are really about 1 3/4" x 3 3/4"
my father owns a carpentry business....thats the only reason i know
You should be fine w/ what you've got
2x4's mass produced are 1.5" x 3.5" The reason for this is its cheaper to produce smaller 2x4's that still do the job (holding the required amount of weight) and they can produce more from the source wood. The smaller 2x4's get away with it because building code has changed the required spacing of 2x4's from 18" center to center to 16" (I'm pretty sure about that ...)
If you get 3/4" MDF it should be 3/4" thick. And it is. I just measured some I have in the garage.
x2
3/4 inch mdf is 3/4 .... it isnt fabricated its pressed
its also 4'1" x 8'1"
its always fun when i tell the guy at lowes that its actually 49 inches wide and he persists to argue with me until he measures it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks...im gonna go head and bring it back...and find the 3/4".....jus to be safe...its gonna be a 8 cu ft box divided in two chambers...4cu ft each....for 2 15"
jcuts7171
jcuts7171
louisiana
jcuts7171
