agdetail
Hi my name is Agdetail, I was wondering if it would be possible to run 3 subwoofers on a Mcintosh MCC301M without any problems power or ohm load wise. The subs I am looking to run are 2 Elate SW 6" subs @ 4 ohms which take a 180w RMS each. And also 1 Ultimo SC 12 inch sub also ran @ 4ohms which will take about 600w RMS. If that is not possible would I be able to run a Elatee 10 inch sub @ 200w RMS instead of the Ultimo 12? I hope someone can answer my questions as my english is not up to par. Thank you my fellow car audio people!
thanks germ305 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
current car is viper and system is stock.
i have a elate 3 way limited edition, mcintosh mx406, mcintosh MCC404M, mcintosh MCC301M, 100sqf fatmat in transit
have yet to decide on cables and fuse. plan to go with tsunami
what i hope to achieve is good sound stage, tight and not overwhelming bass, warm sound.
read that adding coxal in the rear and moving the sub so it faces the rear will improve the sound stage. is that true?
