billybrown66
ive decided to go with the mb quart reference line of amps for my system. an raa 4200 for my components and rear and either an raa1000 or 2400 for my 12" avalanche. here are the specs:
raa1000 -
Dimensions (W x D x H): 11 in x 15.7 in x 2.3 in
Amplifier Type: Amplifier 1-channel
Response Bandwidth: 10 - 250 Hz
Amplifier Output Details: 1000 Watt - 1 Ohm - THD 1.0% - 14.4V DC - 1 channel(s)
500 Watt - 2 Ohm - THD 1.0% - 14.4V DC - 1 channel(s)
250 Watt - 4 Ohm - THD 1.0% - 14.4V DC - 1 channel(s)
Manufacturer Warranty: Limited warranty - 1 year
Audio Performance
Signal-To-Noise Ratio: 85 dB
Continuous Power / Channel Qty: 250 Watts x 1
Amplifier Output: 1-channel
Input Signal Voltage: 0.15 - 8V
Crossover: Active crossover
Crossover Slope: 12 dB/octave
Low Pass Frequencies: 50 - 250 Hz
Total Harmonic Distortion: 0.01
Output Power (total): 1000 Watt
Additional Features: Subsonic filter
raa 2400 -
Amplifier Type: 2-channel
Response Bandwidth: 10 - 40000 Hz
Amplifier Output Details: 400 Watt - 2 Ohm - THD 0.5% - 14.4V DC - 2 channel(s)
200 Watt - 4 Ohm - 14.4V DC - 2 channel(s)
800 Watt - 4 Ohm - 14.4V DC - 1 channel(s)
Audio Performance
Signal-To-Noise Ratio: 95 dB
Continuous Power / Channel Qty: 200 Watts x 2
Amplifier Output: 2-channel
Low Pass Frequencies: 50 - 500 Hz, 500 - 5000 Hz
High Pass Frequencies: 50 - 500 Hz, 500 - 5000 Hz
Total Harmonic Distortion: 0.005
Output Power (total): 800 Watt
Additional Features: Input level controls
the box for my sub would be sealed at the proper alignment (.707), so i figure i could either bridge the raa2400 into 4ohm's which would give me 800 watts running to the sub or just run the ra1000 at 1ohm and get 1000 watts. also, does anyone know about the efficiency of these amps, ive read some reviews but havent heard anything about how much power they draw.
edit: since the avalanche is a 4ohm sub, would there be any benefit from running the 2400?
raa1000 -
Audio Performance
raa 2400 -
Audio Performance
