bump for total specs
» mono subwoofer car amplifier
» 250 watts RMS x 1 at 4 ohms (500 watts x 1 at 2 ohms)
» 1000 watts RMS x 1 at 1 ohm (1-ohm stable)
» variable low-pass filter (50-250 Hz at 12 dB per octave)
» variable Bass EQ frequency adjustment
» variable subsonic filter (15-50 Hz)
» variable phase control (0-180 degrees)
» external wired gain and bass boost controller
» CEA-2006 compliant
» preamp-level inputs and outputs
» front end defeat bypasses gain and crossover controls
» fuse rating: 40A x 3
» 4-gauge power and ground leads with 150A ANL fuse and holder recommended — wiring and hardware not included with amplifier
» 11-7/16"W x 2-3/8"H x 17"D
