Got a real nice MBQuart RAA 1000 class d mono amp.I down sized my vehicle and this amp is large and powerful.i was only running 1 15 and it rocked!
This is all whats included:Amp,box,manual,1 power and 2 speaker plugs,remote that has a volume and bass boost on the same box and the cable.
The 2 side covers are there,there is 1 screw missing on the side panel and there is also 1 set screw missing from the second speaker plug.I will se if i can find it or have another.
Any questions just ask,amp is pretty good shape,i'd say a 8.5 to 9 visually and 10/10 electrically.Amp works great,however,i cant be there to hook this up,so its sold as is,no returns.It will be shipped fedex ground and insured also.Everything weighs 21 lbs.boxed up.
This amp was from the pre maxsonic days,when people from rockford fosgate designed them.Read the reviews...
http://www.crutchfield.com/S-wcc6DCglDPt/App/Product/Item/Main.aspx?i=049RAA1000&search=mb+quart+raa1000&tp=115&tab=review
mono subwoofer car amplifier
250 watts RMS x 1 at 4 ohms (500 watts x 1 at 2 ohms)
1000 watts RMS x 1 at 1 ohm (1-ohm stable)
variable low-pass filter (50-250 Hz at 12 dB per octave)
variable Bass EQ frequency adjustment
variable subsonic filter (15-50 Hz)
variable phase control (0-180 degrees)
external wired gain and bass boost controller
CEA-2006 compliant
preamp-level inputs and outputs
front end defeat bypasses gain and crossover controls
fuse rating: 40A x 3
4-gauge power and ground leads with 150A ANL fuse and holder recommended — wiring and hardware not included with amplifier
11-7/16"W x 2-3/8"H x 17"D
was asking 200,needs to go,$175 shipped w/fees.
CEA-2006 compliant
