MB Quart QAA4250 plus Z6's = Audio Bliss?
I wonder how the Q amps will react to a 3 ohm load. They have a switch for 2 or 4 ohms, which way are you going?
From what i read in the manual, you can set it to 2 ohm and it will take 4ohm loadas well on that setting, so i am thinking 3 ohm would be fine. You just can not set it to 4ohm and run 2 or 3 ohm load.
My QA is slated to arrive by UPS tomorrow. I plan on powering the CDT's with it. Can someone explain what difference you will see when using 250x2@4 Ohm compared to 250x2@ 2 Ohm? If the speakers can take it then what is the advantage or disadvantage of one over the other?
There is a switch for either on the amp....most likey used if you are running subs bridged at a 2 ohm load. According to the manual:
LOAD IMPEDANCE
This optimizes the output section to match the speaker impedance. With the switch in the up
position, the impedance is set to 4 (ohms). With the switch in the down position, the
impedance is set to 2 (ohms). The setting on this switch should match the impedance of
the speakers connected to the amplifier. Failure to do so may cause damage to the speakers
and/or amplifier.
Bridging
The QAA4250 is capable of bridging the rear channels to create a three-channel amplifier. This configuration
is typically used to drive stereo components plus a subwoofer. When using the amplifier in bridge mode, the
Right-Rear (RR) input becomes the sole input for the bridged channel. The front channels remain independent
and require their own signals. The speaker terminals are labeled for both 4-channel and bridge mode
operation, please refer to the diagram for proper load connections.
NOTE: When bridging the amplifier with the load impedance selector switch set to 2 (ohms),
the ideal rear channel load impedance is 4 (ohms). If the load impedance selector switch is set to
4 (ohms), the ideal rear impedance is 8 (ohms).
Got mine today //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Anyone want to see pics? It is awfully thick //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
Colin+M
Colin+M
small town, AL
Colin+M
