Massive V500.2
g6ryder
Used. I would rate 7/10 cosmetically but judge for yourself! I still have OG box as well. Works great hooked up for very short time. Missing one screw.
Volt Series Full Range Class A/B 2-Channel Car Amplifier
RMS Power Rating:
4 ohms: 50 watts x 2 chan.
2 ohms: 80 watts x 2 chan.
Peak Power Rating:
Bridged, 4 ohms: 160 watts x 1 chan.
Max power output: 250 watts x 2 chan.
MOSFET power supply
LED power (green) and protect (red) indicators
Illuminated soft blue logo
Ground loop isolator
Proprietary noise rejection circuit
Hi-Fi E-Cap filter with wide dynamic range for clearer sound reproduction
Variable Bass Boost (0 to +12 dB bass boost at 45 Hz)
Soft Start Turn-on
2/1 channel operation
Speaker-level (high-level) inputs
4-Way System Protection circuitry (Reverse, thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Input sensitivity:
Low level: 200mV-5V
Variable high-pass filter (50-750 Hz, 12 dB/octave)
Variable low-pass filter (50-750 Hz, 12 dB/octave)
Buil-in subsonic filter at 25 Hz
Damping factor: >200
CEA-2006 compliant amplifier
Frequency response: 20-30,000 Hz
Dimensions: 9-5/16"L x 7-13/16"W x 1-15/16"H
$45 shipped
NO TRADES
g6ryder
g6ryder
Claremore, OK
g6ryder
