trumpet
Barry Schanz
Closeout Special - Save Big on Massive Audio NX3
Quantities are limited. When this is gone you will not get this special offer again.
Looking to upgrade your front speakers and add a subwoofer? A 3 channel amplifier is two amplifiers in one chassis. Simplify your installation with less equipment and fewer wires.
Features:
Specifications:
$200 shipped with ground shipping to the lower 48 states
For all other locations a quote is required.
New in box with warranty
Features:
- Extreme Power in a Small Footprint
- Ultimate Mounting Flexibility (Stackable, Line Array & Side Mount)
- Mil Spec Double Sided PCB with SMD Parts
- Built-in Noise Reduction Circuitry
- Full Mosfet with High Grade Switching Devices
- Next Generation Advanced Protection Circuitry
- World Wide Standard Compliant (RoHS, E8, CEA-2006 & CE)
- Micro Circuit Topology
- 1pr Hi/Low Pass RCA Inputs + 1pr RCA Sub Input
- Hybrid Design Class "AB" + Class "D"
Specifications:
- Weight 13 Pounds
- RMS Power 120w x 2 (4 ohms) + 800w x 1 (1 ohm)
- RMS @ 2 Ohms 240w x 2 + 600w x 1
- Bridged RMS 480w x 1 (4 ohms) + 800w x 1
- Min Impedance 2 Ohm x 2 + 1 Ohm x 1
- Min Ohm Bridged 4 Ohm Mono
- THD
- S/N 80 dB
- Max Voltage 15v
- Max RCA Voltage 5v
- Freq. Responce 30Hz - 90Hz
- Dimensions 13.2 (in) x 5.5 (in) x 2.1 (in)
