dbeez
Yeah when you told me 20" I misunderstood and cut the pvc 20" then with the flares it was like 26" total that put me at 32.So I cut 6" off and got me to the 36hz I needed and now i have to fix voltage problems and get some better 8gauge wire with the crap I used my amp actually sees 1 ohm so I have some work to do...And I am sure I can get a tad more out of it..Sounds good and hitting that 150 off of only one saz-3000 is a good score. I bet it's vicious on music. Where did you settle on your tuning? Last I read you were between 32-36hz. If that's still the case then your #s can easily jump up 1+db with a higher "spl" tune.
