Memphis 4k, but the Sundown is nice too //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I believe it was 150.x sealed legal, and 53's outlaw, no headrest scores...That's pretty darn good man. Congrats! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I believe Twistid is pulling 51.x with two 12's and Sundown amps.
Oh no sir i will be putting another SAZ-3000D or 2 35000D's on them and that will be optimum size for them...You need bigger.
Never know unless you test itOh no sir i will be putting another SAZ-3000D or 2 35000D's on them and that will be optimum size for them...
after talking with derrick824 and he does a shit ton of testing on sundown amps and subs in a 96 explorer this will be the best box for my goals..Never know unless you test itBut, I would think that 5 cubes or small would be good for SPL, especially considering your Explorer likes a high note.
I'm missing how that info is relevant to the amount of volume needed for a NightShade 18". Different subs do different things in different setups. If you think it is relevant though I had two NightShade 15s in only 6ft on 3kw that literally blew my sunroof out and also vibrated the small side window in my Explorer so bad it twisted and I had to catch it from falling out.Dunno. Had two SPL-15's in 12 cubes on 4kw and they were ripping the plastic molding off the truck they were in...
There is my man this box is killer and does well need to step up the power and fix voltage and I will be very happy...I'm missing how that info is relevant to the amount of volume needed for a NightShade 18". Different subs do different things in different setups. If you think it is relevant though I had two NightShade 15s in only 6ft on 3kw that literally blew my sunroof out and also vibrated the small side window in my Explorer so bad it twisted and I had to catch it from falling out.
Yeah but for daily how much will that hurt I want this to be as musical and daily friendly as possible..you could go smaller ....i test a little also ...
Sounds good and hitting that 150 off of only one saz-3000 is a good score. I bet it's vicious on music. Where did you settle on your tuning? Last I read you were between 32-36hz. If that's still the case then your #s can easily jump up 1+db with a higher "spl" tune.There is my man this box is killer and does well need to step up the power and fix voltage and I will be very happy...
it could hurt that a little ...i was just throwing it out there ..Yeah but for daily how much will that hurt I want this to be as musical and daily friendly as possible..
