MA Audio Amp or similarly powered used sub amp
kahlilj
GA
I read a post somewhere in the classifieds forum here that someone has this amp. I think its a M1900. If that's you please contact me.
I'm looking for a used (or new if possible) sub amp with about 500 amps RMS with freq response 20hz to 200hz or higher price range less than $85
Thanks for the suggestion chevyguy. my sub is rated for 200W @4 ohms. I prefer to have an amp rated for almost twice that @ 4 ohms. Amp's specs say 240W @ 4 ohms for this amp. do you think this amp will push more and closer to 350 or 400 W @ 4 ohms?
best go with a 2 channel then. What model is the sub and impedance
10" eclipse sw6103 not sure about impedance. I think 4 ohms
What about this amp?
Planet audio PX1500M
Axis Series Monoblock
RMS Power Rating:
4 ohms: 450 watts x 1 chan.
Max power output: 1500 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Variable Bass Boost (0 to +18 dB bass boost at 50 Hz)
Heavy duty aluminum alloy heat-sink
Variable low-pass filter (35-160 Hz, 12 dB/octave)
Subsonic filter (15-40 Hz)
Frequency response: 10-200 Hz
those planet audio amps are horrible. overrated badly and a high failure rate, stay away.
You need to know your subwoofers impedance and if its single or dual coil when picking an amp to match.
I thought planet audio was decent? Oh well. Any other brands to suggest besides PPI? Is SSL crap too?
I think the sub is DVC 4 ohms/ coil. But will need to check once I get home
I think the sub is DVC 4 ohms/ coil. But will need to check once I home
planet audio is crap now, same as boss on most of there lines, same with SSL. Sounds like you need a 2ohm monoblock
kahlilj
kahlilj
GA
evilmonstertruk
