M3a (2 pieces)
  • 4
DUMPED
Great North
DD M3A
BRAND NEW IN BOX
650 SHIPPED and INSURED
M3a Features
The M3a has been our most popular high powered amp for many years. The M3 was never designed for spec power, but was one of the first amps in this power range to utilize a high capacity quad power supply and rock solid output section. The M3a continues the tradition delivering over 3000 Watts of long term, SQ quality, RMS power at alternator charging levels. The M3a has been the go-to amp of choice for high performance sub systems. Specifications Input Sensitivity 0.15V - 5V Variable High Pass Filter Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct Variable Sub-sonic Filter 10Hz - 50Hz @ 24dB/Oct Variable Bass Boost 0-6dB @ 45Hz Tested Voltage 12v -14v Tested THD ≥1% damping Factor Signal to Noise >100dB Channels 1 Cont Power at 1 ohm 2200W x 1 @ 12v Cont Power at 2 ohm Cont Power at 4 ohm Bridged Dynamic Power 4000W x 1ch Efficiency thru Output Dimensions - mm 546.1L x 232W x 63.5H Dimensions - inches 21.5L x 9.13W x 2.5L Shipping Weight 21 lbs
I have 2 of the amplifiers.
They are both BRAND NEW IN THE BOX.
I took out one just to snap a couple of pics.
I am selling EACH one for $650 shipped/insured.
DUMPED
DUMPED
Great North
DUMPED
    May 16, 2024
    May 16, 2024
