Sold M1-ATX PSU + VoomPC Enclosure
oswhiteboy
Remember Katrina
I'm selling my Carputer Car PC System - M1-ATX PSU + VoomPC Enclosure. I purchased this about a month ago and I ran out of time and money on this project. THIS MINI ATX IS BRAND NEW NEVER BEEN USED. COMES WITH POWER SUPPLY AND SOFTWARE. I bought the mini atx for 400, for all the details please read below.Im willing to depart with the MINI ATX for 350 OBO...PLEASE PM ME FOR ALL INQUIRIES. I AM PAYPAL VERIFIED!
Carputer Car PC System:
Jetway VIA C7 1.5GHz Mini-ITX Motherboard + M1-ATX Automotive Power Supply + VoomPC Enclosure + Kingston 512MB DDR2 533 Memory + Toshiba 80GB SATA 2.5" Hard Drive
This Completed Car PC system comes with a Jetway VIA C7 1.5GHz Mini-ITX Motherboard, M1-ATX automotive power supply, VoomPC Enclosure, Kingston 512MB DDR2 Memory, and 80GB SATA 2.5" Hard Drive. This Car PC system comes pre-assembled and tested. All you need is to install your own Operating System, Car PC Software, and Touch Screen LCD.
1. Jetway VIA C7 1.5GHz CN700 Mini-ITX Motherboard
- Manufacturer P/N: J7F2WE-1G5D-OC-LF
- VIA C7 1.5Ghz Processor (25W CPU Power Consumption)
- VIA CN700 + 8237RP
- Front Side Bus: 400MHz
- Graphic Interface: integrated 128bit 2D/3D VIA S3 Graphics UniChrome Pro Processor
- 1 x 240-pin DDR2 Module Sockets Support Max 1GB
- Audio: Onboard 6-Channel CODEC Compliant to AC 97'
- On Board 1394a Port
- Onboard I/O: 8xUSB 2.0 Ports
- Serial ATA: 2 SATA connectors
- TV-out (PAL / NTSC): VIA VT1622A TV encoder
- Expansion Slot: 1xPCI Slot (PCI 2.2)
- VT6103 10/100 Ethernet
- Optional add-on boards
- Dimensions : 170x170mm
- RoHS compliant
# Processor VIA C7 1.5GHz Processor (25W CPU Power Consumption)
# Chipset VIA CN700 North Bridge
# VIA VT8237RP South Bridge
# Expansion Slot Support 1 x PCI Slot (PCI 2.2)
# On Board 1394a Port (for 627FE/627FWE) Compliant with 1394a OHCI specification Version 1.0
# Compliant with IEEE 1394a-2000 standard, support 400Mbit/s
# System Memory 1 x 240-pin DDR2 Module Sockets Support Max 1GB, 1.9V DDR2 400MHz SDRAM
# Support 8/16/32 /64MB frame buffer
# Magic Settings Support CPU Front Side Bus step by step setting in BIOS SETUP
# VGA 16/32/64MB frame buffer using system memory
# internal AGP 8X performance
# 128bit 2D/3D VIA S3 Graphics UniChrome Pro Processor
# 24bit true-color RAMDAC up to 250MHZ pixel
# UltraDMA 133 2 X UltraDMA 133 IDE Interface (Up to 4 IDE Devices & 133MB/s transfer rate)
# ATAPI IDE CD-ROM, CD-R,CD-RW and LS-120 Support
# Onboard LAN IEEE 802.3 10/100 BASE T Standard
# Boot On LAN function
# Onboard Audio Software Audio Controller with Onboard 6-Channel CODEC Compliant to AC 97'
# Support 3D Surround & Positioning, Full Duplex
# Serial ATA Support 2 Serial ATA Port provides 150MB/s (Max.) Data transfer rate
# Support RAID0, RAID1 function
# TV-OUT VIA VT 1622A TV encoder
# Support NTSC/PAL TV system S-Video/AV Output
# PC'99 Colorful I/O Ports 8xUSB 2.0 Ports, 1xParallel Port, 1xVGA Port, 2xSerial Ports(1xheader,1xConn.)
# 1xPS/2 Keyboard Port, 1xPS/2 Mouse Port, 1xFloppy Port
# Line-in/out/MIC Audio Ports
# Optional add-on boards PCMCIA /CF reader, 1 x LAN port, 3 x LAN ports, 2 x serial COM ports
# Form Factor 17 cm x 17 cm
2. M1-ATX Car PC 160W DC-DC Automotive Power Supply
Smart Car PC Power Supply
- ATX, 6-24V wide input range
- Intelligent shutdown controller
- ON/OFF motherboard control
- Survives vehicle engine cranks
- Battery deep discharge prevention
- High efficiency, 90 watts output
3. VoomPC Car PC Aluminum Enclosure
The VoomPC car PC enclosure can take one 2.5" notebook size hard drive, mounted on silicone rubber shock-mounts, easy install under the seat or trunk of the car. The VoomPC enclosure can fit M1-ATX or M2-ATX power supply.
Dimensions: 210mm (8.3") x 254mm (10") x 56mm (2.2") WxLxH
Weight: 3.7 kg ( 8 Ibs )
Case Includes:
* Silicone rubber shock-mount for HDD
* External power cable
Color: Blue
4. Kingston 512MB 240-pin DDR2 533 Memory
* Mfr Part Number: KVR533D2N4/512
* Unbuffered 512MB 533MHz DDR2 Non-ECC CL4 DIMM
* Lifetime Warranty
5. Toshiba 80GB (MK8034GSX) SATA 2.5" Notebook Hard Drive
* Mfr Part Number: HDD2D38 9.5MM
* Capacity: 80GB
* Rotational Speed: 5,400 rpm
* Cache: 8MB
* Interface: SATA 150
* Max. External Transfer Rate: 150MB/s
* Average Seek Time: 12ms
* RoHS Compliant
Is it a M1 or a M2?
If you decide to part I'm interested in it (no matter which one it is) Thanks
oswhiteboy
Remember Katrina
oswhiteboy
Ocean Springs/MS
snoopdan
