Loooking for Test Tones...
Fi_
King of Diamonds
I need 80hz, 25hz and 50hz all 0dB sine waves going to set my LPF,SubSonic and Gains with these thanks. I found some on a site but it doesn't say if they are 0dB or not. and Realm of Excursion is down and they only have -4.6dB I want 0dB.
ok when I use audacity what do I set amplitude to? if I set it to 0 it shows no wave, if I set it to 1 it shows a wave... I want 0db, 50hz. 0dB 80hz, 0dB 25hz
OK, let's see if I can describe this correctly. Open the program and click on "Generate" to get the first pulldown menu, then select "Tone". A pop-up called "Tone Generator" will appear. Enter the freq you want to generate and leave all other settings alone. Now you should have a blue bar near the top of the screen with a section on the left side that says "Audio Track". This is where you set your desired gain level. The slide bar with the "+" and "-" signs controls the level. Dead center is 0dB, far left is -36dB and far right is +36dB. Adjust as desired. Try it out and let me know how it goes! Good luck!!
Fi_
King of Diamonds
Fi_
Fryeburg
Chrisw21
