look what came... dhl ftw but i got an issue!
Have you tried to verify the Thiel/Small parameters to see what size box and the amount of port it needs?
You cant just stick a sub in any old box, the box has to be right for the sub.
ok this box was built for some mtx sub's by me! it has a single port for each sub! anyhow i know i cant throw a sub in any enclosure! but i figured it is a 1.25 internal after all displacement.... it should have done better i would have thought! i was wrong but im no professional box builder or designer! now the question at hand is if i add another port will it help my situation? or will it make thing's worse?
any actual help is appreciated.....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What model # is it?
I have Bass Box Pro, and if that model is already listed I can check it out for you.
The alternative would be if you could just provide the T/L numbers I can manually enter them.
it is the soundstream t2 tarantula 10 the model # is t2-10
Driver Properties
Type: Standard one-way driver
Company: Soundstream Technologies Corp.
Comment: Tarantula series
No. of Drivers = 1
Dual voice coils = separate
Fs = 33 Hz
Qms = 6.649
Vas = 0.71 cu.ft
Xmax = 0.41 in
Qes = 0.801
Z = 1 ohm
Pe = 300 watts
Qts = 0.715
2.83-V SPL = 87 dB
Box Properties
Name:
Type: Vented Box
Shape: Prism, square (optimum)
Vb = 1.25 cu.ft
Fb = 31.07 Hz
F3 = 25.2 Hz
Fill = minimal
No. of Vents = 1
Vent shape = round
Vent ends = one flush
With a parallel voice coil-
Driver Properties
No. of Drivers = 1
Dual voice coils = parallel
Fs = 33 Hz
Qms = 6.649
Vas = 0.71 cu.ft
Xmax = 0.41 in
Qes = 0.401
Z = 0.5 ohm
Pe = 600 watts
Qts = 0.378
2.83-V SPL = 93 dB
Box Properties
Name:
Type: Vented Box
Vb = 1.25 cu.ft
Fb = 31.07 Hz
F3 = 28.16 Hz
Fill = minimal
No. of Vents = 1
Vent shape = round
ok this is getting irratating! you can either help or be classified as another useless **** on this forum......help or get out.....thank's:)
the sub isnt loud whatsoever! it is in a 1.2 cubed enclosure tuned to 34 hz!
that is the help, make a bigger box! I used 4 cubes for my t4 12" a while ago.
obviously a T4 and type E wont perform in the same box thats more suited for a type e. type jeez.
Model Sealed Box SizePorted Box SizeTune Freq.# of PortsPort (dia x length)
T2-10 Not Recommended 1.5 cubic feet 40 Hz 1 3" x 5.75"
T2-12 Not Recommended 2.0 cubic feet 38 Hz 1 5" x 14.5"
T2-15 Not Recommended 4.0 cubic feet 38 Hz 1 6" x 8.75"
that is what the manual say's online
my box is .25 cubes off from the manufacturer specs and 5" too long on the port but i dont want the bottom end to be lacking! so i have 1lb of polyfill in the box so my enclosure is around 1.6 cubes.........hmmm almost what the specs ask for
mike dressure
enthusiast
mike dressure
mt home-boise Idaho
casper97ta
