[LNIB] Kicker Warhorse 10,000 Watts RMS
ahole-ic
Banned
Kicker Warhorse 10,000 watt amplifier
This amplifier was recently traded to me from a respected forum member "Wone". I have unboxed it only to take pictures of it and to power it up on my bench to make sure that it does in fact power on. I see no scratches or any markings. It looks mint.
Specs taken from sonicelectronix:
Warhorse Series Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 5,000 watts x 1 chan.
2 ohms: 10,000 watts x 1 chan.
Max power output: 20,000 watts x 1 chan.
Signal Modulated power supply allows for ultra-high-efficiency
Wired remote bass level control included
Unique power supply allows for amplifier to output 10,000 watts with 90% efficiency
8 green LED indicators display the status of the amplifiers protective circuitry and assists in troubleshooting
Variable Bass Boost (0 to +18 dB bass boost at 40 Hz)
Preamp RCA outputs to daisy chain multiple amps
Separate voice coil wiring terminals allows for user to hook up each subwoofer voice coil to dedicated terminal
High-density split-dome convection heat sink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Input sensitivity:
Low level: 170mV-5V
Variable low-pass filter (50-200 Hz, 24 dB/octave)
High Pass Subsonic filter (20-60 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-200 Hz
Dimensions: 35"L x 17-3/4"W x 3-3/4"H
Minimum Power Requirements: Eight 12-volt Batteries, and two 200-Ampere Alternators. For more information regarding the Warhorse Power Requirements, please read the User Manual
Triple 1/0-gauge power and ground wiring is required for installation.
$1300.00 Shipped.
Shipping is included in the price
My check just cleared, I could afford this, but I don't support Ecrack in any of his endeavors. //content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif
get ahold of him on his forum or if you want another way to get ahold of him pm me
Umm, I bought this Warhorse from eCrack about a month ago. By the time I powered it up to test (which worked flawlessly) I decided to amp with old school Orion & US Amps.
Its for sale $1300, highest watt Warhorse I've seen at 10,577. Near Topeka, Kansas and I'll be going through KC to Branson,MO pretty soon.
I hope I'm not & odd that ecrack was, talked to him for awhile, seemed like a very good fellow.
I'd only trade back to old school stuff, pre 2000. Orion, PPI, US Amps.
I was planning on a big rig alternator, possibly modded. They're stock 270 amp, fairly inexpensive.
Thats some very inexpensive power at 13 cents a watt. The amp is quite a machine. At near the weight of a sack of concrete & bigger than a suitcase I had to take a peek inside to make sure there wasn't a chunk of iron in there for ballast. Nope, just a lot of thick shiney copper and rack of caps. Reminded me of Phoenix Gold guts, nice. A plexi windowed Warhorse would make an awesome show with 10k of go.
Heres your answer //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
NEW KICKER WX10000.1 AMPLIFIER CLASS D MONO AMP 10,000W | eBay
OP nice amp good price, wish i had use for it or id get it. GLWS man
I left them a little note, after they reposted it again for 26k.
Why don't you stop trying to sell this for more than 10x it's value? Authorized dealers would never try to gouge their potential customers in this manner, as I have purchased two of these from an authorized dealer for less than a tenth of that cost. Put this up at a reasonable number, before you are reported for trying to take unsuspecting ebay customers.
ahole-ic
Banned
ahole-ic
Ivory Tower
TurboRedneck
