Lincoln SP-175 Plus MIG welder
k_schutte
I have a lincoln SP-175 Plus MIG welder up for sale. it is the 220 welder, it will need a new set of rollers which are about $40~ and tips. It is on ebay if you want to check out the auction otherwise i will take $500 SHIPPED on here...
THE ONLY TRADE I WOULD CONSIDER IS FOR A 6FT+ ALBINO PYTHON!! DO NOT WASTE TIME OFFERING ANYTHING ELSE UNLESS IT IS CASH!! ONLY REASON I AM SELLING THIS IS TO BUY A SNAKE!!
The unit features continuous control of both voltage and wire feed speed for infinite control of welding procedures. It is ideal for those with access to 208/230 volts input power. For welding steel, stainless steel and aluminum. Package includes gun and cable, work clamp and cable, input power cord, guide tubes and drive rolls, gas solenoid valve, and gas regulator.
Features:
- Designed for .023"-.030" solid MIG wire, and .035" flux-cored wire.
- Suitable for welding .023"-.035" stainless steel and .035" aluminum.
- Large, easy to set knobs provides continuous full range control of both wire speed and voltage procedures.
- For welding 24 gauge through 5/16" mild steel plate.
Processes:
- MIG
- Flux-Cored
Rated Output - 130 amps, 20 volts, 30% duty cycle
Output Range (Amps) - DC: 25 - 175
Wire Speed Range - 50 - 400 ipm (1.3 - 10.2m/min)
Dimensions - 12 x 9.75 x 16.5 in (30 5 x 248 x 419mm)
Net Weight - 60 lbs
here is some more info: http://content.lincolnelectric.com/pdfs/products/navigator/im/IM790.pdf
not sure if it is OK to post the ebay link or not? since i have at cheaper on here may be it is OK...? if not please delete that part!
here is the ebay link: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160348644553
k_schutte
k_schutte
cedar rapids, IA
k_schutte
