A post to one of my threads on another forum about my BX1605d:
____________________________________________
Your running a Brutus amp to those ??? If So you might want to open the amp up and place rubber cushions under the circuit board, and apply sone silicone heat tranfer paste to all the power devices and then reassemble the amp.
ALL Hifonics Brutus amps have a 1 to 2 year life span because of vibration damage to the electronics inside.
The circuit board has no support in the middle so all the bass your making will cause it to reasonate. And this causes lead frame failure on the outputs. Then they go shorted VIOLA BLOWN AMP ! ...
I have seen the over 60 times in these amps. I even sent a load of amps back to Zenon Electronics limited of Hong Kong China because of this ****ed up mechanical assembly of these types of amps.
Nice speakers man, But you should try and fix your amp before it goes up in smoke, from shock vibration. I'm telling you the truth about the Brutus amps. It's what I do for a living... Good Luck on your system
Has anyone experienced this? What should I do?? I don't want to have to have a funeral for my amp.//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
