LED's
xKronicx
I want to install some LEDs lights onto my radio dash. I already have the LEDs ready but im not sure were a good power source is to power them up so they will shut off with the radio. I am thinking about wiring to the radio power supply but im not sure if that will drain the power going to the radio and i dont wont to blow the fuse on my radio also.
NO! the remote wire turns your amps on.. this will be a red wire i believe.. the leds probably need a ground to don't they? if so you need to ground em by tapping into the radio ground
Ohh alright.
Soo if i do it your way by using the red wire, will i need a replay like "moronlib" said?
Yeah i think the red wire is the ignition wire. So when the key turns the radio comes on.
But will this take power out from the radio?
Ohh alright.Soo if i do it your way by using the red wire, will i need a replay like "moronlib" said?
how many you using? and we talking led bulbs like individuals or what?
well i have a few of them now.
How many can i use?
Yes its the small individual led bulbs.
Yeah i am going to look up the wire diagram before i hook stuff up! But should i plug it into the ignition and ground it? Will it get power from the ignition wire?
xKronicx
xKronicx
Lawrenceville,GA
xKronicx
