Lanzar Vibe 248 Amp ...
KB15
Lanzar #VIBE248
1200 Watt 2 Channel Amp
* Mosfet Power Supply
* 2 x 300 Watts RMS at 4 Ohms
* 2 x 600 Watts Max at 4 Ohms
* 1 x 1200 Watts Max at 4 Ohms Bridged
* 2 x 500 Watts at 2 Ohms
* Electronic Crossover Network
* Bass Boost Circuit
* Bridgeable at 4 Ohms
* 2 Ohms Stereo Stable
* Tri-Mode Capable
* Gold RCA Inputs
* Line Outs For Left & Right Channels.
* Power & Protection LED Indicators
* Advanced Protection Circuitry
* Soft Turn On/Off
* Remote Control Bass Booster
* Frequency Response: 15 Hz - 35 kHz
* S/N ratio: 90dB
* Dimensions: 11.5"W x 2.3"H x 15"L
Now i got that 2 push my 2 12 inch Lanzar Heritage 124Ds
#HRW124D - 12" 1000 Watt Dual Voice Coil Woofer
# 80 Oz Strontium Magnet Structure
# Power Handling: 500 Watts RMS / 1000 Watts Peak
# Frequency Response: 30-1KHz
# DualVoice Coil System
# Impedance(Per Coil): 4 Ohms
# Efficiency: 88dB
BOx is a Sealed with 4 4inch vents on each corner. How the box by the way?
All i gota get is some speakers now and im pretty good for 350 CAD i think i got an alright deal. Now any idea how many AMPS the amp going to be pushing out i dont know about the Ohms and everything. So how does the system seem ? 1-10 id give it like a 7 a high 7 im really happy with how its going id give it higher but again its Lanzar and not JBL or JL.
ok stuff to start with imo, but the 248 is never going to sniff 1000w rms. I would expect about 250w to each sub, 300 if you're lucky. Plenty to get good results. Unless you have an unusually small electrical system, current draw shouldn't be a problem.
2 decent subs, a decent amp, and an enclosure sounds like a pretty good deal for $350 CAD
the 248 will output ~1kw.
I'd used 4 of them in my old Grand Am install with Strokers at the time.
The Viberant 248's are good for ~1.0 - 1.1 kw @ 3.2ish dcr with a 13.5-14.0 vdc supply. Well, the four that I used were according to the fluke dmm.
I dunno about sniffing them tho... I never tried to have them sniff anything.
-Nick
KB15
KB15
Toronto,Canada
Nikuk
