Lanzar VCHB212 2 12" any good?
hutt132
US
I've been looking at Lanzar VCHB212 (currently $110) and was wondering if they are any good. I want clear and solid bass. I plan to power them with a Hifonics ZRX500.2 (currently $85) amp.
The reason I chose those speakers is because I have a S10 with a small cab so there isn't much room and I'm on a budget so I can't go for anything more expensive.
Stay away from anything lanzar besides the OPTI line. The only good low end sub is the LANZAR MAX ST not the PRO and it is still pretty shitty
What subwoofer pre-installed in a box would you recommend? 12"D max 21"W max
I don't know how to install speakers into enclosures. What about a Sony XS-GTX121LS, Pioneer TS-SWX251, or Kicker TC104 (10TC104)? Those are pre installed in an enclosure but have a single voice coil. Are any of those any good?
I suggest you do some serious reading and research before you buy anything then
I did some looking around and found a Ground Shaker ST 1 12-BLACK box. I had to pick this one because my truck is so small. I also found a Rockford Fosgate PRIME R1S412 sub. It was really hard to find a nice one that would fit in the box. Is that sub any good?
Depends on what you expect to achieve from your setup
Clear and hard hitting bass. Doesn't need to be too loud.
That statement makes no sense.
If it was 'hard hitting' it would be loud.
I am quite sure that you, and 90% of people, cannot tell if bass is distorted or 'clear'
I think you need to read these forums some more, listen to some systems, and then decide on what you want.
hutt132
hutt132
US
>>SQL<<
