Sold ````lanzar Opti2000d For Sale!!----!@#
cdimic25
Rating: 91.7%
11 1 0
I am selling my Lanzar opti2000d because im moving onto more power. Two Sundown 1500d's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. I always set the gains with a DMM to 42v (1800 watts) and was wired to 1 ohm, even though they can handle .5.
Info from lanzar:
SPECS
700 Watts RMS Power @ 4 Ohms
1100 Watts RMS Power @ 2 Ohms
1600 Watts RMS Power @ 1.3 Ohms
2000 Watts Max Power @ 0.5 Ohms
4000 Watts Bridge Max Power @ 2 Ohms
Mono Block Subwoofer Amplifier
0.5 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Remote Bass Control
Soft Turn On/Off
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to 18dB
Variable Phase Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 6
Dimensions: 10.08'' (W) x 2.12'' (H) x 19.1'' (L)
If you are viewing this you know what the opti series amps can do, rated and more //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Im already missing this amp waiting to strap my other sundown in //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
PICS:
Price: 250 OBO
cdimic25
cdimic25
Echo42987
