L5 vs L7
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif How big is your booty?//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif If u dont know put mirror behind ur legs and stick your face between your legs and see how big it is:crazy:
pretty much its power handling, the cone is a lil different than the L5, but i think depending on if you have low wattage or high is where youll know the real decision btw the two. Example, if you bought a jbl 1200.1 and 2 12 L5s, that would be a perfect setup as each sub is 600 watts rms each!!! Just think, you have to get at least a 1500 watt amp to power those L7s to there max rms power!!!!
How big is your booty? If u dont know put mirror behind ur legs and stick your face between your legs and see how big it is
or just look backwards into a mirror //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif that always help to look at y0 azz !!!
more_ spl or whatever your fuking name is; You are a fuking idiot. Get the fuk off this fuking web site and go fuking ******** while you look at your own fuking *** in the fuking mirror.
Any way the L7 also performs better in a ported ( or vented as kicker calls it) enclosure.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i sense a bit of hostility coming from the new guy :p
alot of peeps on this board are to "up there"... you need to relax a bit and go with the flow. sometimes a funny crack is good instead of "all install" and "100% tech"...
learn to lighten up dude. i was just going along with the first post
Thanks and have a nice day a.s.s.h.o.l.e //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by more_spl i sense a bit of hostility coming from the new guy :p
well said
infinifosgate
infinifosgate
wisconsin
Vorak
BP1Fanatic
BP1Fanatic
