L5 to L7 help please
90accordman
I'm Currently running 2 L5 12's in a 5.4cube port box tuned to 32hz. I'm wondering what my sound difference will be if i just switch out the L5s for L7s of the same size, would it be worth the speakers or not.
I am running the L5s together at about 1100 watts and would be using the L7s the same way.
Am I looking at lower bass, more sound output, or will it be about the same given the same power and box?
ask polecat but from my experences id only use an l7 if i had more ower than an l5. they can sound alot alike but the l7 can sound a little deeper not much though also depends on the box
if you have the power, use the L7...but if power remains the same, and your not hurting the L5, stay with it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
im running 1100 watts to the L5s but i have to have everything low is why i asked.
IFB-2340 Series (Big Boy) Class AB amplifiers
Model*
IFB-2340C Number of Channels 2 Peak Power 2200W RMS Power @ 4 ohm stereo 340W x 2
RMS Power @ 2 ohm stereo 680W x 2
Bridged RMS Power @ 4 ohm 1100W x 1 Frequency Response 10Hz-40KHz Signal to noise ratio 105dB Input Sensitivity Dual Range .3V-10V/8V-17V Power Supply
Power consumption 120A 240A
Fuses 40A x 3 40A x 6
THD (4 ohm stereo @ low) .04% THD @ 10W .04% THD @ 10W
Dimensions (W x H x D) 9 3/4" x 2 2/10" x 24 2/5" 9 3/4" x 2 2/10" x 54"
I;m running them bridged at 4 ohms, would the L7s at 2ohm be better or not really.
90accordman
90accordman
Fresno, CA
Polecat
